Judson 02 prespray
vincent
Vincent Sapp
Who uses it in a hydroforce and what are your fix ratios?
Also do you apply it at the same psi you clean with?
ACE
Mikey,
Can you make a room dedicated to questions about Judson Jizz?
Jesse
For us, usually 16oz per 7qt sprayer 1:4 (no tip) applied @ 800psi unless it's a really dirty then 500psi draws better, I'd go to 300 if I was treating a bad spot but usually it's better to make a stronger mix and save the time @ 800psi.
We soak em so psi save lots of time
I also add things to it besides the modifier.... It's compatible w/ everything I like to boost with.
Wandslinger
Tom Meyer
8 to 10 ounces for one gallon of water in the Hydraforce, 500 PSI and no tip.
Yes its thick.. shake well before pouring and before using in the HF. we use 16 oz at 4-600 for most jobs. If I think it needs the Hot Sauce I'll add five heaping teaspoons. It has taken care of everything I wanted it to when I use it. If its really dirty and I know ahead of time, I'll go nuclear on it with Grease Eraser or other high pH like powerburst, enzall, etc..
I mix a 10liter jug with 16oz of O2, pour that into a HF jug with a yellow tip (1:8), apply with around 500psi
Shane T
Shane Tiegs
Ditto! Notice this without a metering tip. With this setup it even pulls chem at 200 degrees.
