davegillfishing
I will be using this as a 3rd truck but mostly directing its use as the flood truck. I'm going to upgrade it to high flow and the upgraded valve and the silencer over the muffler but the questions are should I go ahead and upgrade the btu or is it hot with the stock burner? Any advantages to upgrading other than more heat?
Also what do they charge to install audit into a small box truck?
Ian asking here because I figure they are closed for the holidays and I just prepping to pull the trigger mid jan. indeed to find a diesel box truck first
Thanks for any and all advise and direction
Dave
Dave
