Jack Zipper Zerkie
Received the new low budget wand$ 229.00 plus shipping. The wand is shorter than the other two jet wand that Iv,e been using, both 1.5 hose and 12 wide for old guys like me. I cleaned a vacant unit with berber and started with the old Cobb wand two jets 110-03 and glide the carpet cleaned good. Then used the new Cobb wand with two 110-02 jets and a metal glide, this wand cleaned better and drier, but had a problem with pulling the wand on the back stroke due to the berber carpet but was not a problem with the other wand with the white glide. The white glides slide better , but the metal glide removes more moisture as it has a larger open bottom.
The next job was also empty but had no power, the cleaning people were to vacum but it never happend so the new wand made a big difference, the old wand only picks up moisture with the white glide. The new wand picks up everything, had to clean the base a few times from all the hairs. I will use the new wand as much as I can and only use the old wand as needed. The light weight is great to use all day, and for the low price its well worth the money. Easier and drier. Thank you Larry Cobb!
