- Joined
- Oct 7, 2006
- Messages
- 10,877
- Name
- Jim Martin
and lets keep the personal BS out of it and keep on track with performance....
how much time are you really wasting pre vacuuming compared to having to always clean out your filters.....
or having to filter your water before you dump.....
Before I ever put a glide on my wand my filters were always full of dirt and mostly fibers.....it was always restricting my vacuum and my dry times were even effected...the performance of the machine had dropped...
sometimes I would have to stop and clean the filter in the middle of a job to keep it going...or having to clean them before the next job...I also noticed way back when I started running a glide that I was getting way less fibers and dirt then I normally did before I ran a glide....So by not vacuuming and running a glide are you leaving all this on the floor...we all know the glide is great for lift and dry times but not good at picking up most things...and if it is making it out to your truck...are you standing out there in the cold trying to clean a filter for the next job because of how restricted it is...Or are you just running all day with a restricted filter and bogging down your equipment and making it and you work harder...
Speaking for myself....I pre vacuum...not for the impression for the client but for my own benefit...I run all day long with the same filter....( modified pool filter..most have seen it)...and I can clean 4 homes easy and not have to worry about it getting restricted or losing any of my performance on my equipment..I rinse my waste tank out once a month and have no build up what so ever.....that in itself is worth the extra effort to me to vacuum...
