Lg heater question
joeynbgky
Cleaning Professional
Joey
After using my ne machine today.... it was a lot hotter than my old one.
I have had my jets cleaned out and I delime it. Does this thing need taken apart and delimed? Someone once told me to take it apart and soak something. But I'm dumb I didn't know what they were talking about
Sent from my g2 using tapatalk. Whofat
joeynbgky
Joey
Thanks. Bertz sucks
joeynbgky
Joey
Ive done all that. So there is no other place to delime it? Like taking the coils out
joeynbgky
Joey
Guess ill have to take it into the shop
just be sure whatever you use to descale it doesn't corrode the copper
and hello everything works better when its new....
check the regulator if there is a difference
maybe you didn't descale it thoroughly enough
that's what I figure
rwcarpet
Robert Hodge
Are you using any type of water softener? A softener can help reduce any build up in the heater and the plumbing. I've gone 8 years with my Genesis without any descaling. (or de-liming, as you call it)
dgardner
A couple things to consider:
The LG works by raising the water temp a certain amount. If your incoming water happens to be warmer on that day, your water at the wand will be that much warmer too.
Also, the LG is sensitive to flow. If you are using a wand on your new machine that has different (smaller) jetting, your water will be hotter as well.
joeynbgky
Joey
Its fixed. I needed a new pressure regulator. For. Some reason a gewy liquid poored out of it
ding ding i win.....
what do i win???
