lime stone cleaning help
Jtuseo
I have a job to clean limestone with peices of Granite in the lime stone. They need to be cleaned and sealed. What good products do you recommend? Also what do I use to make it shine again?
I by means am not an expert in this but I would check if there is a topical coating, if not just hit it with a n alkaline and turbo it off. Then get some monkey pads and follow directions.
Bee Busy
u should pass and call a local stone expert...call Stu Rosen at MB Stone in NY
fresh1
by all means proceed with the above recommendations. After all what could go wrong?
I'd be glad to email you a copy of my manual introducing stone maintenance. There is basic information on cleaning travertine. Just send me an email and I will attach it to the reply. scottw@bridgewatercorp.net
Why should he pass on a job?
I don't like leaving money on the table. He would have to do something stupid to hurt the floor. If he is concerned just document all flaws and concerns before cleaning, having the authorized person sign off and proceed with caution. It will be a learning experience but he must be able to educate the customer about expectations and results with only cleaning.
Jtuseo said:
Is it the same as cleaning marble? I do Marble all the time.
Cleaning limestone or Travertine is very similar to cleaning marble. Limestone and travertine are often finished at a lower gloss level than marble (honed rather than polished). Travertine has the voids which may be filled with resin, grout or other materials. The cleaner needs to be careful with possibility of dislodging the filler material and cleaning down into the voids if they are not filled.
Shane Deubell
Vacuum really well, keep dwell time to a minimum and use a brush ring on turbo.
We use stonetech products klenzall and heavy duty sealer.
