Lint bags
bob vawter
Grassy Knoller
bob vawter
That's exactly the reason that the Steam Genie was the best damned machine ever built....no Lint boxes lint bags or anything else to worry about.....
I bet ya I can remove ..spray off and replace my filter BEFORE you even get yors out....so there!!!!
Art Kelly was gonna GIVE me his wm.....I looked at that cockamamie filter system and politely told him no thanks....
My butler only has the in tank filter at this point. using it for hot mop water mostly and to hose off windows and siding.
I'll probably get something newer in a year or two and let Genny keep the butler.
And I don't have time to mess with rearranging things at this point. Don't have a decent shop neither. Once the new shop is built and I get things set up the way I want ill probably be as old as you and just not care.
Seriously my tools are scattered between a shed my basement and the new storage unit. I need this building which is on the list for spring and then I can start thinking about projects again. I'm tired stressed and physically wore out.
That's a stupid reason not to take advantage of his good nature. Wish he would've offered it to me.
great
then you'd have THREE worn out direct drive units....
huh??
You bought a TM to fill mop buckets and use as a 1000 psi pressure washer ???
Not why I bought it but what it became.
My two worn out units made us over $163,000 last year without thousand dollar payments. Some large repair bills but still a lot cheaper than a brand new one. And actually they have been very dependable too. Most repairs have been to the van not the machine. And more precautionary than needed.
I don't like new things. Old dirty and tattered so I don't feel the need to keep it polished or worry about tree beaches in driveways or driving in rain snow and mud.
I like to tinker with things. Take them apart figure them out turn some wrenches. On new stuff I hate to touch it. Afraid to scratch it or break it then I get upset.
I like to use things not look at how pretty it is.
it's the same
Only worse with a direct drive due to not being able to swap out TM into a fresh van
but if you're happy, I'm happy for you
bob vawter
Grassy Knoller
bob vawter
trying to quit smoking
failing miserably
but succeeding enough to be irritable AF
soooo....don't get in my way....:evil:
Let's see here......I believe I smelled camel
Straights....right? Do you roll the pack up in yor shirt sleeve....
LARRY.....you ain't gonna quit....I called you out on more than a few occasions of not having sufficient willpower to do so.....
Maybe an oral fixation .......not sure!
Now on the OTHER hand....I been quit for right at 15 years now.....my wife is going on 12.....
Will power Larr......easy peesy!
'cides in my case it took the heart attack to make me realize how foul and disgusting a smoker really is......OHH YA....and stupit!
But not to worry bud......I'll toss a pack in the box wit ya....jus as they lower the lid....no lighter tho.....and I'll laugh and laugh!
it's the same
From what I've been reading here guys are making thousand dollar payments and repair bills.
And I can swap a pto into a new van too. Actually want to put in an older panel truck.
And for the record I like the 2002 $3000 WM better than the 2010 $20,000 butler. Might have to put a tranny in the WM and keep it going a few more years. Its been weak since I got it and my mechanic looked at it when I got it and said the band's looked terrible. There is a long pause before it grabs when I put it in gear and the rpms are high getting it moving. Once it gets up to speed it seems ok.
The motor uses a lot of oil but seems ok otherwise. Probably a loss of horse power though.
bob vawter
Grassy Knoller
bob vawter
yea??
maybe in a $500 '78 church van like Bob ran .
But figure you might be in over your hED on a late model van??
LARR if you put $500 into a church bus instead of 20 grand on a newer one......
YOU JUS MADE 19500.00 THOUSAND UNTAXABLE DOLLARS!
PLUS you won't back over mailboxes cuz ya got windows to see out.......
Ever do that.....HUH?
Talked to a fellow gunnut friend that happens to be a respiratory doc .
I asked him about Chantix
his reply,
"larry, if you don't want to quit, nothing will work"
That's always been (and still is) my problem.
I don't "want" to quit , but "should" quit for all the right and sensible reasons
butt..if I do, I'll keep a pack just like I keep a bottle of bourbon .
so, toss them both in the dED carcass box at my funeral
Reactions: steve_64
bob vawter
Grassy Knoller
bob vawter
his reply,
Now that WOULD be a waste of good bourbon!
But I would have a remember Larry garage party......and set the bottle up with the rest
Of the DED soldiers!
Reactions: Trip Moses
yea??
For about $5,000 modernistic will pull and install for me. Already been looking into it.
But guess you would be surprised at what I've accomplished in my life. I may seem like a big goof here but there's a reason for that too.
so what exactly is Spicolli doing to filter his vacuum?
nothing?
Right now nothing. I do have the blower filter. My sewer clean out is covered in ice and snow so I'm dumping onsite or in my gravel parking space for now.
Don't you know who Jay is? More fitting I thought.
Latest Auctions
