LOOK OUT! Steamin Demon! .... CFX
S
Scott Rogers
Dominick Cassano said:
You can introduce an emulsifier into the water stream by attaching a modified injection sprayer full of emulsifier inline from the sink. You'd have to retrofit that sprayer by attaching a small 5' piece of pressure hose to the inlet side so you can hook it to the sink, and then on the outlet side eliminate the lance and trigger valve and hook up a QD in its place so you can hook your pressure line there going to your wand.
Better and much cheaper option
http://www.northerntool.com/webapp/wcs/ ... _200335637
J
-JB-
That's all that need done using high flow, I'd hate to think how much detergent you'd use if you retrofitted a high flow machine w/some sorta meeter, OYE!
