juniorc82
I was changing the oil in the white magic. I had the ball valve open on the cat pump which I was unaware of. Since the pump and engine share a mutual drain resivoir , I also drained the cat pump along with the engine. I put oil in the engine and went and cleaned the olive garden. I noticed after about an hour of run time the wand started sputtering almost like a machine gun. Went out side to check and heard a loud screech. The pulley on the pump locked up . After pricing a rebuild I said screw it and am having james at carpet solutions in st louis put a new one on tomarrow. I figure with the machine having 1700 hours this is one less component I will have to worry about. I feel so stupid for making such a bone head mistake. I think I may have him splice a second ball valve in the drain line so there will be a fail safe for future oil changes.
