Mike call me your phone does not work
  • Thread starter Ivan Day Soap Free Procyon
  • Start date
So don't deal coke if it's that simple, can't understand why you want to sell that stuff when your are "that company" making over 10 grand in one day.
D
dgardner
Step 2.
Try not to giggle when they tell you that the OP only guy tossed a tantrum when he was told his services were no longer needed
Step 3 through 16
3. Pre vac with Kirby and or Royal
4. Give tutorial on why a Meile cannister with hard surface head is doing a horrible job as well as pulling yarns out by the 1000s
5. Use Multi Sprayer with 02 tip to apply Procyon Extreme
6. Agitation with 10" Brush Pro with soft brushes
7. Rinse with 13" 5 flow Zipper and or 4 flow 12" Sapphire Titanium.
8. Monitor Aerotech and it's 250 hose runs because when you tech asks why your 13 inch Zipper is so much harder to push than the 15inch and you figure out that the vacuum relief is stuck at 22 inches, you're gonna freak the fvck out
9. Interlink Fab Set rinse
10.Lots of dry strokes
11. Apply water based FPA
12. Groom
13. Set up fans
14. Post vac
15. Try to be humble when each and every house staff worker and low to upper management member tells you how incredibly better it looks
15.5 Use simple terms and analogies when comparing OP to extraction methods
16. Start looking for hotels in San Francisco, Pebble Beach and Palm Springs for when their other homes need real cleaning..
Sounds like an awesome day and a great strategy.
We did 9 frigging stop for $1700 today 2 trucks
I'm beat. Probably did over 7k sq ft worth of carpet between 2 trucks.
So your in Santa Cruz working for your Son???
How much did he pay you to drive out and assist on that job????
Reactions: dgardner
So, did you use your heat like Bill Sourpus suggested, or what?
120°ish
Three areas needed a second application of PE and re- rinsing
The silk content was a complete non issue
Cleaning anything with cold water is just plain stupid. After all, we don't own Recoils!
Was that sour enough for ya!
When we clean wool rugs in the shop, if it's a bleeder, we use cold water. When we clean viscose rugs, we use cold water, silk area rugs, we use cold water. Blood/milk/egg removal, we use cold water. There is a time for heat and a time not use it. Hot water is fine for wool broadloom in a home or office within reason. I probably wouldn't use a kero fired burner turned up to the max on it.
Pic
120°ish
Pictures look good. Lot's of us would be terrified to do that kind of work. I have a custom goat hair carpet job coming up in the fall. I'll maybe try the same thing
