@rick imby WHATZ UP ? You still using the Savage for a foot stool?
Whaat .. it says dual cord ..
this Mytee ETM will need a generator 4600 watts to run the machine as is. It you want to add heat, then you would need even a larger generator, probably 8000 watts or greater.
Cord Dual
Amp Draw Cord One: 20, Cord Two: 10
The specs I see say two 6.6" vac motors (parallel) and PumpTec pump.
We have three extractors with same vacs, and Cat Pump system for less
Tile & Grout Capable
http://www.cobbcarpet.com/zen/index...escription=1&keyword=MY354+or+DC362+or+MY2152
A machine like that does not and cannot exist. Use your common sense. Each 6.6 vacmotor takes 13-14 amps each. There is 2 cords. A 1000 psi pump will take 10 - 15 amps depending on motor size. There is the third cord. Tile cleaning extractors normally use 2-2 stage vac motors at about 7-8 amps each allowing the machine to run on 2 cords. The problem is if you want to clean carpets, your vacuum isn't all that great. Good for tiles, not so good for carpets.You mention having 3 with same vacs n cat pump for less ..
First one you show, the Mosquito has same vacs and is priced less but only 220 psi
The last one you show the Breeze says high efficency vac with 500psi then 400 psi and is also priced less
Cant really compare these two with the AirFlex .. so cheaper means nothing
The second one you show the Mytee is much closer and a few hundred cheaper but says 1100 air watts and the AirFlex says (625x2) 1250 air watts so pay less for less vac ..
Will or do you have a machine that has the dual 6.6 1250 air watts with a pump to do tile n grout (750-1200) on a dual cord? If so, send all accurate specs for me to consider. Thanks !!
800 psi and a 6.6 vac may be possible on one cord, but it has to be on a 20 amp circuit and even then you may blow breakers here and there.
Agreed in principle Rick, but you have the description backwards. Centrifugal vacs run the lowest speed when moving the most air - the energy spent moving that air loads (and slows down) the motor. When you add resistance (drawing a vacuum and therefore moving less air) the vac speeds up because of the lower load. Put your hand over any porty or shop vac and you can hear the speed increase - and the amps go down.One of the portable secrets most people don't know is never start your porty up without your vac hoses and wand already hooked up. Rotary vac motors pull more power the higher rpm they are running at. When you add resistance to the vacuum the power demand is lower. Putting a glide on your wand will help keep your porty from blowing fuses also....
That's pretty good for a 3/4 hp motor. I have an older leeson 3/4 hp powering a small general pump. At 1200 psi, it takes aprox 11 amps. The motor gets pretty hot. I really should use a 1-1 1/2. A 6.6 may drop 1-1.5 amps with hoses and wand connected, down to maybe 12 amps. Do you running any cooling fans on that motor?Just checked on our 3/4 HP motor at the shop.
It is very efficient construction & only draws 7.0 amps @ 3/4 HP .
So it can run @ 2 GPM , 700 PSI with a 6.6" vac on a 20 amp circuit.
First portable that can do that using a 3/4 HP motor.
http://www.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=85&products_id=5203
Spend money on marketing or/and a TM .I clicked on to one of your links which say 500psi but then shows the 1XP which goes 100-800 psi .. so would this be (2) 6.6 vac motors, the 1xp puimp auto pump out on 2 cords only? How many inches of lift are we talking?
I have a 1000DX200 .. would I be able to swap pump out for the 1xp?
I had one of thee airflex's, got rid of it.
It wouldnt suck the smoke off a fag.
Simply Upgrade your porty with new HP vacuum motors and a larger pump . Dimensions available for proper fit.
Kleenrite will beat all others for price. 6.6s $100 5.7s ditto
Airwatts say 100 still .. wouldnt it be 1250?
Completely correct.Series - higher lift
Parallel - higher cfms
Higher lift seems like it would draw more from the floor but flow slower back to the porty where parallel would draw less from the floor but carry it back faster to the porty ..?
I start my machine choked if i'm riding the limit in a home. Dead end the vac hose and start the motors.Agreed in principle Rick, but you have the description backwards. Centrifugal vacs run the lowest speed when moving the most air - the energy spent moving that air loads (and slows down) the motor. When you add resistance (drawing a vacuum and therefore moving less air) the vac speeds up because of the lower load. Put your hand over any porty or shop vac and you can hear the speed increase - and the amps go down.
But I definitely agree that starting the vac(s) only after you have attached the hose, wand, and glide will draw the lowest amps and give you the best shot at not tripping breakers.
If your statement had said "centrifugal vac motors pull more power the more air they move" then I would agree 100% with what you said.
Howd you get one .. they told me they wouldnt sell to the US unless a distributer took on a truckload and that none have been sold here to date.
Unless youre from another country?
CIMEXGees dual 8.4 vacs
Im looking to maximize power using 2 cords no heater. Capable of doing tile n grout and carpet with a long hose run (min 75 ft) and a pump out system. The longest hose run possible while keeping my combo.
Im guessing the dual 6.6 and Cat 1xp will be my combo?
Thanks !!
Ive considered the Goliath 4 vac system 2 in series and 2 parallel along with the 1200 psi Water Otter .. but Id either have 3 cords to monkey with or a super long pressure line running from the janitors closet (which is where Id plug the WO into) all over the areas to be cleaned which could require 150-200ft of line
Im trying to figure out a way to clean without pissing people off (while theyre on their phones) with the loud ass porties .. its a high turnover call center and its mostly the newbies that look at us like WTH .. were always getting the dirty looks .. etc ..
Sometimes I feel rushed cause Im sitting in one spot too long .. which can be stressful !!
CIMEX
