more cleaner?
  • Thread starter prestige cleaner
  • Start date
P
prestige cleaner
what would get carpets more throughly clean if i used my sebo brush followed by flushing with wand vs. prespraying then using the 360i.
Cleaning Professional
You might see the difference but you will sure know there is one.
try speed wanding, ie at the speed someone would need to move it to go over 1000sf in an hour
Then do a slower wand path.
You will see a difference
Bob Foster
No need to both Sebo and 360. 360 is way more aggressive than a Sebo.
Prevac, pre-spray and then 360.
ACE
The 360 might be "more cleaner" than a CRB and wand but the production rate is going to be damn slow. I bought a 360 earlier in the year but ended up shelving the thing because I was hitting the busy season. The CRB / wand method works great with a 2 man crew. Is anyone dual wanding with two 360s on a regualar basis? It does not seem to need much vacuum.
L
lance
PS, 360i, PS, sebo fast, wand. Bet this gets it really clean. Have Ron come over and pre-vac for you.
Ace, what crb are you using and what brushes are on it?
