FB7777
Bane Clene is Back BABY!!!
Bane-Clene’s Super Aqua-Mount® Auxiliary Vacuum Unit may be retrofitted to Bane-Clene Maxi-Mount® or Para-Mount® truckmounted carpet cleaning equipment manufactured before 2005 for extra vacuum, especially for pump-outs.
This unit employs a specially engineered auxiliary 5 hp 230 volt electric motor and positive displacement vacuum pump to more efficiently evacuate water without adding dangerous and costly gasoline or propane-powered generators to your operation.
Within seconds, the Super Aqua-Mount will allow the operator to transfer from a normal quiet and efficient cleaning mode to a higher velocity, quick-recovery flood water removal system. This is performed by a simple switch of a vacuum hose - and it is still electric!
The Bane-Clene engineered Super Aqua-Mount system is a definite requirement for your fleet if water restoration is projected to play a prominent role in your service business. Near-impossible drying times can now be achieved in those highly time-sensitive cleaning jobs.
•Power Unit: All Electric, 230V, 60 Hz Single Phase, 19.2 amp HD Motor Unit with Sealed Bearings. Requires no Maintenance.
•Vacuum System: Positive Displacement, Modified SAV, Cast Iron, 2" Intake and Outtake Ports with impeller construction. 163 CFM at 10" Hg.
•Weight: Approximately 225 lbs. Size: 22" H x 18" W x 32" L
•Power: Use 5,000 watt generator (min.) or 220 hook-up at job site.
Yikes! Either you bring a Generator to power the unit or move out the stove or electric dryer to plug in for a whopping 163CFM !!!
I suppose thats all you need when your water pump is only capable of 200 PSI of 120 degree water
This unit and a ParaMount System will set you back almost $25,000 LMAO
