DevilThomas
- Joined
- Apr 4, 2009
- Messages
- 675
I had Terry build me a 150 psi "toolbox" sized demand pump/sprayer ...
It is the perfect companion for my duel cord CFX.
I presprayed 2000 sqft house today in 12 minutes flat!
I put a 5 gal bucket in the tub, filled it with 4 gals water, added O2, and was ready to go. After prespraying I rinsed bucket and filled with water, letting hot water run very slowly...excess overflowing and going down the drain. Then hooked my wand and Rotovac 360 to pump and did the job. Worked perfectly.
Terry did a great job...Mytee 150psi pump, fittings mounted thru box, syphon hose, cord, all fitting inside the toolbox housing...quality made...made to last. Looked "factory" made.
I would recommend this to anyone needing a kick-ass pre-sprayer, and as a quality backup pump...allowing you to finish any job. Its a carry anywhere pump, weighing only 6 lbs or so.
Thank you Terry...its just what I wanted ...to use with my CFX. Perfect for prespray for OP application too!
Anyone looking for a better sprayer...this is it!!!
