B&BGaryC
- Joined
- Apr 6, 2007
- Messages
- 4,667
- Name
- B&BGaryC
Is there any adjustment or easy fix on this or will I be battling this the whole time? Pressure set at 375, brass jets, just what came in it.
[/quote:g2pib90s]Royal Man said:Bob,
Your picture of your wand is not at cleaning height. (It is in a holder on your van)At cleaning height the tube is practically parallel to the carpet. More like the picture I posted.(depending on the height of the operator.)
Notice the wear angle on the glide
You might want to also notice the Glide on the wand Cobb posted. The slot is not even on the carpet because the wand is raise higher than optimum height.
[quote="Bob Foster":g2pib90s]
Jimmy L said:SATAN of course you don't know what you are talking about.
My old CASTEX 16 inch wand has it so the jets are adjustable. You can position the bar to spray straight down if you want.I have mine positioned to spray just right behind the SS glides. The distance of the spray is 2 inches away from the carpet. The spray bar itself is 4 inches high from the carpet as I stand up with it.
The gap of the slot opening is 1/4 inch . This coupled with the twin SS glides prevents it from LOCKING down on a carpet.
I have been with this bitch about 15 years now. We are secret lovers, I stroke her and make her squirt. And when I put her to bed I tell her how much I love her.
The bentley is just a copy of an older better design like the castex.
The bentley will never be the whore like my castex baby!
FishinTime said:Every time I've used a multiple jet wand it seems to streek on certain carpets. I use a single jet wand even thouh the jet is higher off the carpet and theres some heat loss it sprays evenly on the carpet. I always scrub my carpets so the loss of heat is not a big factor.
The only exception would be the Steam Way wand, though the cleaning is best toward the middle of the wand. This wand uses a flood jet about 2 inches from the carpet and has a fully enclosed heat chamber, so impact agitation and heat are maximized.Lee Stockwell said:I carry three wands on the truck, deferring to Murphy.
The fewer jets a wand has the farther they must be from the carpet, and the jets are usually bigger. Result: less clogging, less impact and less problem with higher pressure. For a newbie these 1 or 2-jets are good tradeoffs.
Wands with 4 or more jets have them closer to the carpet to get proper spray patterns. They must be filtered better to avoid clogging, but deliver great impact and heat retention for superior cleaning versus the 2-jet, all other things held equal.
If you don't understand these differences you can damage some carpets or do a poor cleaning job.
Thanks,
Lee
