- Joined
- Oct 7, 2006
- Messages
- 49,918
Exactly my point.
Something that is well engineered can be very complex yet intuitive and easy to operate (like the IPhone in your hand). Well engineered things don't appear to be complex, which means that unless you're an engineer, you probably won't appreciate the thought that went into a design....
Sent from my ADR6300 using Tapatalk 2
There is a point at which "well engineered" becomes over-engineered. That point is directly correlated with the point at which that machine becomes difficult to work on.
TCS is sitting right at the apex.
And has been for over 30 years.
- How frequently (preferably infrequently) it breaks down.
- How many hours you can put on it that is fairly trouble free.
- How long does it last.
- How much maintenance does it need?
The rest for me is pretty much fluff.
If the machine is a dependable work horse, I am willing to pay more for it and it is well worth it for me.I don't have the talent, the wish for, or the time to crawl under the hood. And I don't enjoy it either.
I haven't met a carpet cleaner that is a good mechanic yet.
.Marty, Sorry to bring you back to the subject I raised.
I don't care if the machine is over or under engineered. All I care about is:
My TCS units almost never break down, if your definition of a break down is one where it breaks and leaves you stranded. That happened to me a couple of months ago when both blower belts blew and I can to the office to get a replacement set and realized I didn't have a freaking replacement set. What a freaking dumb assed move! I normally keep a spare fuel pump on hand, a set of replacement belts and that's it. The fuel pumps will go out on you in the blink of an eye, about once every two years, or so. Takes about 2 minutes to change one out. The belts go about every three to four years. Takes about 10 minutes to change out. The only "major" think on these engines that you sometimes have to deal with is valve cover gaskets and head gaskets going out. When they go on you, you aren't dead in the water. You just see leaking oil or you hear hissing air and you start to notice your engine performing poorly over time. You always have plenty of time to schedule the repair.[/COLOR]- How many hours you can put on it that is fairly trouble free
Normally, I can expect somewhere around 2500 hours before I start noticing an oil leak from my valve covers and have to replace them. Somewhere between 2500 hours and 5000 hours, you ARE going to blow a head gasket or two. Minor repair that takes no real time. The rest of the time, you're just going to deal with piddly little things like cleaning burner rings, changing oil, filters and plugs.
Almost all of anyone heres natural life. You will replace your original engine within 5 to 8 years, normally and will have to have your pump rebuilt somewhere during that time. Other than that, the van itself will let you down before any major component of the TM does.- How much maintenance does it need?
Change the plugs, filters and oil every 50 machine hours. I don't keep up with hours, so I change all these things when I first notice the oil turning dark. Works out to be, for me, about once a month. Once a year, I drive over to TCS and have them change my blower and pump oils (I certainly could do this myself, but I always go to TCS because I need a chemical run). I will have them change out my waste tank gasket while I am there. (Easy to do yourself as well.) I have them check my belts and tweek this or any of that they find and I am out the door in under two hours.
So if TCS machines are good on all of these issues, in my book they're great and worth every penny.
My CDS sees the shop about once a year for maintenance, and that's about it. + The occasional repair (very rarely). 12 years old and made me plenty of relatively trouble free money. To me, that's what its all about.
The only way I would consider purchasing a CDS is if I were either running several crews, or the unit was only going to be used by me. I have discussed my reasoning related to this on several occasions and I am sure you read every work in breathless anticipation, so I will not bore you any further with that information.
Believe it baby. How do you think Butler can get away with having zero local customer support? To me, that's scary. I guess Butler owners just dump them and get new after five years.I "hear" guys like you saying they go five years without ever turning a wrench on their van driven units quite often. I don't believe any of it.
Don't get me wrong I am happy with my machine. It just had a hell of a break in period andI relize that while yes I saved some money in the beginning it did come at a cost. Its running great now and kicking ass Dnt get m wrong Im not writing a thread to bash the small manufacturer I am posting a thread on the merit of doing business with a major manufacturer. I am still pleased that I got the unit because all the parts I can get localy ad ts an open style unit so I can do a lot more service y self. I just wonder when it comes to putting a fulltime second truck on the road if I will go with the consistency of a bigger brand.
Were all your problems really the machine, or was it a lack of maintenance by the prior owner?
previous owner??
I believe he bought it brand new
