FOJL
- Joined
- Oct 7, 2006
- Messages
- 18,851
- Name
- Lee Stockwell
What is the OEM solution hose with the Everest now?
								Steam is over 300 degrees f. We use hot water.lol...leave it to Cobb.
NOT FOR STEAM USE!
or they're not using Parker endsI tried buying pre crimped Parflex from Cobb and the fittings would blow/fail, I took it to my Parker shop and no issue
Knowing Larry, his monkeys are using vice grips to put his hoses together.
High temp setting is 270 I believe. I run it on medium and it sits at exactly 220.I was saying my temp is 250+. The temp gauge is maxed out where there’s no number. Which shows it’s somewhere between 250-260. I’m literally holding that trigger at 12flow maintaining that high of temp. Your 570 temp stays that hot also???
And my wood chopping carpet is dryer than yours. MoronHis wand strokes still look like he's chopping wood.
Doubtful.And my wood chopping carpet is dryer than yours. Moron
You fookers should just come out, so you can start swapping spit!And my wood chopping carpet is dryer than yours. Moron
Thanks @Tom Forsythe and @scottw for jumping on this problem. My hydroforce came in today. I’m sure it’ll perform good. It was the hose I used before I had the OEM nylon hose.I've been trying to buy Interlink's HF hose for a freaking week now! Last week I ordered it, waited a couple day for a tracking number...nothing. Then I tried it again, waited a couple days for a tracking number...nothing again. I log in to my account and it shows I never purchased it. Is anyone having trouble with purchasing things on their stupid website? I tried to pm Scott, but he's too busy teaching how to clean piss off wool rugs. @Tom Forsythe, can you take a break from sniffing all your presprays and help me out? Also...since I'm getting pissed just thinking about it, put me on a different distributor. I can't stand DixieSteamway in Alabama. Why don't I have one here in Georgia for faster shipping? I need this hose before Saturday and I've been trying to order it for a week Now!!!
I'm sorry. I thought you just switched. But no padding?There's very few times I use pads under furniture. Sorry, but I've got more important stuff to do. When the customer isn't there, the dog and pony stays out in the truck.
Not porty? I've only used a truckmount for 16years, never had a porty.
Very few times I'll use plastic under the legs. I'm very careful NOT to spray the legs with my hydroforce to make the legs wet which would weaken the furniture dye and the only times I put plastic under the legs is if bare metal or older wooden legs are on it. I do triple the dry passes under the furniture and have never had an issue.I'm sorry. I thought you just switched. But no padding?
Don't skimp on the furniture protection Matt. It will bite you one day. Buy the 4 inch pads and keep them in a shirt pocket. Doesn't take long and then you know you don't have to worry.Very few times I'll use plastic under the legs. I'm very careful NOT to spray the legs with my hydroforce to make the legs wet which would weaken the furniture dye and the only times I put plastic under the legs is if bare metal or older wooden legs are on it. I do triple the dry passes under the furniture and have never had an issue.
I have an OCD with keeping the wand moving. When I have to put the wand down to move furniture, pull hose back, or put plastic under legs, it really bothers me. I feel like I'm losing money when the wand isn't moving. One reason I bought this tm is so I could increase the flow on my wand with more steady heat and do less wet passes.
I'm hiring help this weekend to help me this summer, and hopefully after, so maybe we can keep that wand moving
If you never move the furniture, you don't know if it's bled or not. There are some pieces that will bleed if you just look at them funny. You've just been lucky so far.16 years of my process and 45+% of repeat customers in the last 6months. I’m doing something right
Go back to the trade thread and harass Boyle.If you never move the furniture, you don't know if it's bled or not. There are some pieces that will bleed if you just look at them funny. You've just been lucky so far.
It's more fun harassing you. You leave yourself wide open for criticism. Sometimes you even learn something, although grudgingly.Go back to the trade thread and harass Boyle.
I've had plastic legs bleed or crock or whatever you call it.If you never move the furniture, you don't know if it's bled or not. There are some pieces that will bleed if you just look at them funny. You've just been lucky so far.
Good luck with the new help. Been through two kids already but looks like Cooper is sticking around.Very few times I'll use plastic under the legs. I'm very careful NOT to spray the legs with my hydroforce to make the legs wet which would weaken the furniture dye and the only times I put plastic under the legs is if bare metal or older wooden legs are on it. I do triple the dry passes under the furniture and have never had an issue.
A broken clock is right twice a day!16 years of my process and 45+% of repeat customers in the last 6months. I’m doing something right
