Aug 31, 2011 #1 B Bob Foster Guest Why can't the treads on the new manifold arms be extended to accept a nut that could be put on and threaded back to lock the jet arms into position? :?:
Aug 31, 2011 #3 Larry Cobb Member Joined Oct 7, 2006 Messages 5,795 Name Larry Cobb Bob; We have a lot of the new Bentley manifolds out in the field. The jet positions do not get changed easily . . . and my customers are fairly rough on them. That stainless is substanial. Larry
Aug 31, 2011 #4 Mikey P Administrator Joined Oct 6, 2006 Messages 117,079 BS! The damn thing gets knocked ouf of position with a strong wind.
Aug 31, 2011 #6 Larry Cobb Member Joined Oct 7, 2006 Messages 5,795 Name Larry Cobb If you're hitting the jet manifold hard enough to move the elbows . . . then you might want to take a close look at the jets themselves. The jet openings are probably "hammered shut". Larry Bob; Locktite is too mild for these guys . . . just WELD every single piece together
Aug 31, 2011 #7 B Bob Foster Guest My adjustments only recently became annoying and I'm careful with my tools. Will try some blue loctite on them. I really like this wand!!!
Aug 31, 2011 #8 Mikey P Administrator Joined Oct 6, 2006 Messages 117,079 The wand w/ the metal all slot glide cleans great. The manifold assembly needed pipe thread, NOT straight threads. What it really need is a PC Ti wand type manifold set up but that would require a new head casting
