Mytee Wand Manifold and a Pair of Nuts...
Bob Foster
Why can't the treads on the new manifold arms be extended to accept a nut that could be put on and threaded back to lock the jet arms into position? :?:
Bob;
We have a lot of the new Bentley manifolds out in the field.
The jet positions do not get changed easily . . .
and my customers are fairly rough on them.
That stainless is substanial.
BS!
The damn thing gets knocked ouf of position with a strong wind.
If you're hitting the jet manifold hard enough to move the elbows . . .
then you might want to take a close look at the jets themselves.
The jet openings are probably "hammered shut".
Bob; Locktite is too mild for these guys . . .
just WELD every single piece together
Bob Foster
My adjustments only recently became annoying and I'm careful with my tools. Will try some blue loctite on them.
I really like this wand!!!
The wand w/ the metal all slot glide cleans great.
The manifold assembly needed pipe thread, NOT straight threads.
What it really need is a PC Ti wand type manifold set up but that would require a new head casting
