The slide system on the gorilla box. At least make it an option. That thing was Coolio.
A freshwater bladder inside the waste tank. Maybe a small APO system that would pump in to the tank. (100% dad's idea ) allow a small Transit style van to have onboard water. As the freshwater bladder empties it makes room for the waste.
I'd like a PTO system that would run a 59. In a cargo van. I hate having a v8 running and not using the HP.
And. Gauges.
Geez 25 grand. And no oil pressure ,no tach,no engine temp gauge. 75 bucks for a cluster at autozone. A high temp kill switch is fine,but a gauge would make trouble shooting so much easier. The same goes for the charging system and oil pressure. An engine with low oil pressure might not trigger the shutoff but your still doing damage.
Gauges. It always annoyed me that
prochem gives instructions on the proper rpm to set the governor, but the machine has no tach.
