New General Emperor Pump
MB Auctions
Here is your chance to pick up a brand new General Emperor Pressure Pump at a great discount.
Building your own machine?
Need a back up for your Sapphire, Prochem, Hydramaster, Cobb or TCS truckmount?
Model# HTS2215S
$570 value W/Free shipping
Features & Benefits:
The Emperor HTS SeriesGeneral pumpcan run dry for several hours
Water temps up to 185°F
Nickle-plated manifold & valve caps provide corrosion resistant operation and helps reduce damage caused by cavitation
Side sight glass
Direct replacement for Cat 310/5CP2120 with same RPM and Flow
• Features patent-pending “high tech” packings:
-dynamic low-pressure seal retainer
-superior low-pressure seal
-innovative intermediate ring
-superior high-pressure seal
• Ceramic plungers
• Patent-pending inlet/outlet valve cage
• Nickel-plated inlet/outlet valve plugs
• Nickel-plated forged brass manifold with exclusive lifetime warranty
• Heavy-duty tapered roller bearings
• Specifically designed to handle rigorous duty cycles, high temperatures and chemicals
General Pump - HTS2215S - Pressure Washer Pumps
> General Pump HTS2215S Repair Kits & Parts
> General Pump HTS2215S Manufacturer Specs(.PDF format)
SPECIFICATIONS - HTS2215S
Maximum Volume
4.0/5.0 gpm
Max. Discharge Pressure2300 psi
Maximum Pump Speed950/1200 rpm
Maximum Inlet Pressure125 psi
Maximum Inlet Vacuum9 ft. water (7.9 in Hg)
Bore.866 in / 22 mm
Stroke.591 in / 15 mm
Crankcase Oil Capacity40.6 oz
Maximum Fluid Temperature185°F
Inlet Port Thread1/2-14 BSP-F
Discharge Port Thread3/8-19 BSP-F
Shaft Diameter.945 in / 24 mm
Weight32 lbs
Dimensions12.2 x 9.2 x 6.9 in
Actually I'm now running the 5cp I bought from FCC 3 or 4 years ago. Had it sitting in backup all that time, runs great. Need to finally rebuild the General.
Reactions: FB19087
I bid, but didn't get an email notification.
No "bid history" to confirm either. I'll go higher, but hate to bid against myself.
FFA
FFA
What would make the siteglass pop off of one of these? Can i cap it for now or is there internal damage that could have caused this?
Damn..
If it was not over filled and it popped out from pressure...which I doubt as the oil cap should have a relief valve, I'd have to guess its just faulty.
Call over there on Monday and talk to Reed Petersen
Reactions: FFA
FFA
FFA
Damn..
Would you happen to have the phone number?
