MB Auctions
- Joined
- Sep 15, 2014
- Messages
- 92
Here is your chance to pick up a brand new General Emperor Pressure Pump at a great discount.
Building your own machine?
Need a back up for your Sapphire, Prochem, Hydramaster, Cobb or TCS truckmount?
Model# HTS2215S
$570 value W/Free shipping
Features & Benefits:
The Emperor HTS SeriesGeneral pumpcan run dry for several hours
Water temps up to 185°F
Nickle-plated manifold & valve caps provide corrosion resistant operation and helps reduce damage caused by cavitation
Side sight glass
Direct replacement for Cat 310/5CP2120 with same RPM and Flow
• Features patent-pending “high tech” packings:
-dynamic low-pressure seal retainer
-superior low-pressure seal
-innovative intermediate ring
-superior high-pressure seal
• Ceramic plungers
• Patent-pending inlet/outlet valve cage
• Nickel-plated inlet/outlet valve plugs
• Nickel-plated forged brass manifold with exclusive lifetime warranty
• Heavy-duty tapered roller bearings
• Specifically designed to handle rigorous duty cycles, high temperatures and chemicals
General Pump - HTS2215S - Pressure Washer Pumps
> General Pump HTS2215S Repair Kits & Parts
> General Pump HTS2215S Manufacturer Specs(.PDF format)
SPECIFICATIONS - HTS2215S
Maximum Volume4.0/5.0 gpm
Max. Discharge Pressure2300 psi
Maximum Pump Speed950/1200 rpm
Maximum Inlet Pressure125 psi
Maximum Inlet Vacuum9 ft. water (7.9 in Hg)
Bore.866 in / 22 mm
Stroke.591 in / 15 mm
Crankcase Oil Capacity40.6 oz
Maximum Fluid Temperature185°F
Inlet Port Thread1/2-14 BSP-F
Discharge Port Thread3/8-19 BSP-F
Shaft Diameter.945 in / 24 mm
Weight32 lbs
Dimensions12.2 x 9.2 x 6.9 in
Model# HTS2215S
Side sight glass
• Ceramic plungers
Bore.866 in / 22 mm
Weight32 lbs
