New Truck...Heater question??
Jimbo
Cleaning Professional
So I bought out a friend's equipment...
PTO...6008 Blower
SS Waste and fresh tanks...large
Lots of room inside...
I'd just like to get a little more heat...
It has a coolant heat exchanger...And an exhaust heat exchanger...
I'm leaning towards propane...maybe a Hotamatic #4...
What do you guys think?
Would you consider a fuel oil burner unit? Pros and cons?
Thanks in advance!- Jim
ps...I know the 10 foot ceiling in the garage is a little low!
jim that is a loaded question.
what will the truck be used for?
will this be your main truck now?
what heat are you looking to get?
do you mind "BUYING" heat or do you want free heat?
What kind of motor is pushing the heat? ie is that a diesel or is that an ls1 hooked up to 4l60e?
i will call you tommorow as there are some easy ways to pull 'Free" heat out of that system i just need to see the complete coniguration. and i am very interested in seeing the exhaust diverter.
p.s. if you are up now go ahead and give me a ring.
propane...with that little added kick from the current exchanger....
yea youll like it
AshleyMckendree
Ashley Mckendree
Not enough heat from the coolant AND exhaust??
Try descaling the system first, those coils might be coated in scale not giving you 100% of the heat available.
Jimbo
Thanks for the descaling idea, Ashley.
Michael...It is a 4 cyl turbo diesel engine...the GMC W4500 42k miles
I would like it to be my main truck...using the Duramax van with ProChem Everest now
Don't mind buying heat...the gigantor truck only runs about 200 now...after warming it up...I'd like 225 at the start...and be able to adjust up if needed.
The exhaust diverter is a 2" gate valve in the exhaust system...
Jim is the coolant exchanger a box or is it a large tank like a v?
Where is the exhAaust exchanger mounted?
Jimbo
Hey Michael...coolant exchanger is a box...approx size 30' length...18 inches width...14" height ss construction
The exhaust heat exchanger is in the box...just a little smaller in size
I will give you a call just after 8am my time. Thanks
charlie brown
Jim why not hook up the (included) extra throttle cable and bump it up a few hundred RPM'S. This would be my first (inexpensive) try. Which might be enough , do to the 6008 load increase. I looked into Propane to use as a last step booster, but wasn't quite clear about adjusting the temp control knob (higher) and flow etc. The jets would have to be just right so not to need an external flue. Very nice looking truck great presence. Wind shield?
Doug Cox
Doug Cox
How about a hotter thermostat on the machine engine. I have dual liquid exchangers, exhaust exchanger and a blower pre heat exchanger and I can run 240+ all day long.
Jimbo
Custom, Ashley!
Good idea Charlie!...I think it is running a bit slow...I'll check the rpm!
Before you start to change things I think it is important to check the temp rise of both exchangers individually and also make sure that they are running efficiently. Also you might want to consider a coolant preheated fresh tank as that would be more efficient heat transfer overall instead of just A preheating box.
pfft.... ill let you guys know how much better that everest runs with no back pressure on the blower....
little preheat ALLA helicoil (which i think is a cool idea, or judsons one on the reactor)
and a fuel fired one...
and BAM heat out the wazooooo
