New upholstery tool devlopment is coming along..
Bc
Jeff T
Prefer about 20 ft or more.
Yup. If a guy does a ton of upholstery, this is my preferred length aswell.
I run stainless steel braided solution hose inside my vac line on my SS Upholstery Pro tool. When we do large amounts of commercial upholstery, (carpet AND upholstery), without a doubt, I love having a very long lead on my upholstery tool. Still even, when doing a very large sectional, it’s nice to have enough give on the hose to complete the job. I’d never go back to 8-10’.
The tool is really coming along impressively
Two units will be in Indianapolis to play with Screenshot_20250318-213321.png
Bc
Jeff T
Getting sic'er by the minute...
View: https://youtu.be/_v0bQlEUPBs?si=a5dpKjr4Kk_85ndp
Inch and a quarter ultra flexible vac hose with swivel cuff, in 10, 15 & 20' choices.
The optional brass bypass assembly will come with a protective bag for those concerned about scratching delicate floors.
And did I mention the head will most likely be made out of titanium for a 35% weight reduction?
View attachment 130402 View attachment 130403
Looking promising.
I’ll be the first to ask,
Have you decided on pricing yet?
It all looks good so far.
Titanium should make it as light as a plastic tool, with more durability.
The bypass set up might not readily survive careless cleaners/techs, but it seems the bag should help with this. I think the feature is worth this potential issue, as you can control pressure/flow, and I would think it should enable enough flow to activate flow controlled burners.
Will that feature be an option?
Dwain Ray
This is what i use to bypass on all my upholstery tools its built from off the shelf parts from a kleanrite solvent tool. It's simple and can be easily removed if necessary
View attachment 129914 View attachment 129915 View attachment 129916 View attachment 129917 View attachment 129918
Forgot to say , the short teflon hose is there so as the jet of hot solution doesn't cut a hole in vacuum hose(and it would). The teflon hose is connected to a small orifice used inside kleanrite solvent extractors return line
  • Love
Reactions: hogjowl
Bc
Jeff T
My daughter says I’m autistic.
Why not?
It seems all the rage these days 😂
I took my wife and daughters shopping yesterday.
We went out for lunch first, then went to the mall.
As I was following my girls around (11 and 13), they stopped in one of their favourite shops.
I of course, begrudgingly, was only there as a shopping bag holder, and wallet.
As they perused the offerings in this preteen-teen store, I was looking at how strange things have become since my own youth.
I came upon the most bizarre thing I’ve seen in my life.
Apparently, the new thing now is called E.S.S.A….
Emotional
Support
Stuffed
Animals
There were every kind of stuffed animal, and they all had this ESSA embroidered, or a collar, or a harness with this ridiculous name on them.
This is what our society has been reduced to.
Emotional
Support
Stuffed
Animals
Next we will have restaurants banning emotional support stuffed animals or requiring you prove they are really an emotional support stuffed animal.
