Vinnie
- Joined
- Jan 16, 2007
- Messages
- 262
- Name
- Vincent Annunziato
Read below.
Don't take it personal, John. I think ALL lectroweenies suck, not just yours.
Nobody can tell me they have the performance of a positive displacement blower.
So, unless you're broke, why buy one?
You're right about one thing. If you have anything free, you can send it my way.
Come on Piglet you haven't even run it, how can you compare it.Don't take it personal, John. I think ALL lectroweenies suck, not just yours.
bane uses a #3 blower running at 1800 rpm i think it is. been so long since i cared what it was.
I use Johns ETM everyday. I pop a circuit breaker maybe 1 out of 20 jobs. I plug one cord into the kitchen and then the other where ever, if they are on seperate lines it will not pop. The machine has the same suction as other gas truckmounts I have had. Here is the list of truckmounts I have owned, Butler system, Prochem Blazer, Pro Chem Legend and a Chem Tex Black Stallion. The Mytee is the same suction as the Legend in my opionion. The butler suction was better. The Mytee ETM Escape is a rock solid machine, I pump out flooded basements a few times a week with it as well.
I told you we had one for like a decade. Once the energy crisis had passed we used it as an inhouse unit for years until it rusted out and we couldn't use it anymore.The day you buy one, Taco, is the day you can defend their use.
Until then, you're just doing your normal sucking up.
which ain't squat, Bro
the HG (lift) is also way below capacity .
Power requirements only allow Bane to spin an already small bloer at 1/2 it's capacity ..that's what makes it's performance so pitiful
any decent porty with 50ft of hose has as much, or more suck
Bane units are well built .. I'll give Mr Bill that, he builds 'em like a tank , however, they're terribly under powered for a TM.
I have little doubt Mytee John's 4-vac unit will compare favorably or surpass a #3 blower ...maybe even equal a 4 blower.
problem is, you'll need an 18hp generator to power the beast.
You'd be better off using that gas engine to spin a PD blower and pump
..l.T.A.
Bane is direct coupled to a Franklin motor that spinsat 1250 RPM and generates approx 60 CFM Max lift 7 inches mercbane uses a #3 blower running at 1800 rpm i think it is. been so long since i cared what it was.
Ran them for 13 years
I agree Steve, but when I used the HM Bobcats I didn't have the problem. .
Thanks John T.Larry I use the machine with two vac motors. The way the Vacuum motors are installed makes for double the suction. I want everyone to click on this link to see me cleaning with the machine on a long hose run with no booster.
http://www.youtube.com/watch?v=UseRhdagwm0
