odor removal
Donwand
Brian
Any suggestions on removing gasoline odor from the trunk of a car. It coming from the black cushion felt stuff. I've used Odorcide with no luck, but I might try again at full strength.
I appreciate any advice.
Brian
Nothing but time will remove it. Pull carpet. Pitch the fiber pad and clean the metal. Then wait 6-months and it "might" go away. We have tried all sorts of methods and have not found anything that is consistantly effective.
GeneMiller
gene miller
I dealt with that problem 20 years ago. I could not completely get it out. I used a solvent before I started rinsing. Mine was on a glue down and it got into the latex. I might of had a deodorizer but I didn't use it. Good luck
Gene
Scott S.
Scott
Walmart sells a product in the automotive section that says it removes gasoline odor. maybe try that.
Brian, is this your vehicle or a custy's??
if custy...hopefully you per-qualified the custy and aren't on the hook for the additional follow-up attempts
.L.T.A.
When my father used to drive 20 miles to save two cents per gallon at a truckstop I would love to smell that gasoline as I hung my head out the window. Something like 27 cents a gallon? They just don't make gasoline like they used too.
Can you remember what it felt like to have the wind blow through your hair?
Way back when ...
You're kiddin right? He still experinces that feeling today. Any time he stick his ass out the window, which for James can be quite frequent. :winky:
Reactions: Jimmy L
