- Joined
- Oct 6, 2006
- Messages
- 117,122
Looks safe enough for me
are you referring to the original polyurethane finish that came with the wood ?Looks like it has glycol ether in the ingredients and that solvent may take away a little of the shine on some finished wood floors.
But the ZEP for hardwood also has glycol ether.Looks like it has glycol ether in the ingredients and that solvent may take away a little of the shine on some finished wood floors.
Bought some ZEP hardwood/laminate floor cleaner from Menards.
Found it left a residue.
Do the mirror test to see the results.
Been using just glass cleaner and it works better.
I just mist and wipe with a microfiber mop to maintain
Sounds good to me. Where can I buy those encapsulating mops Jimmy.Either ammonia or non ammonia glass cleaner.
You see Richard if you use the ammonia version as you mist the cleaner on the floor...........the sub atomic particles of ammonia will flash off as it makes contact. Thus the moment of contact is very brief. Just enough to dissolve the soil. And enough wetness to be able to gently wipe off. The extracted soil load is then ENCAPSULATED in the microfiber mop. Leaving a RESIDUE FREE surface.
DOESN'T THAT SOUND LIKE ALL THE MARKETING BS THAT SCAMPOO MAKERS USE?
WAKE UP AMERICA!
ENCAPSULATION IS A.................FRAUD!
