Acid Dye Blocker in a pre spray that will attach and stay put during the rinsing process?
Would you need high heat to expand the fibers to get the "blockes" to set?
Hi, this message to let you know that effective immediately our new Acid-Dye Blocking prespray/detergent additive, Block-N-Boost, is now available for purchase and a special discount is in place for the remainer of September 2011.
WHAT IS KLEENSHIELD BLOCK-N-BOOST? KleenShield Block-N-Boost is a revolutionary, breakthrough product which when added to a VacAway presprays/detergent enables you to clean and impart acid-dye stain resistance to nylon or wool carpet in one easy step. It will even give the prespray an effective cleaning boost.
HOW EXACTLY DOES IT WORK? It is loaded with advanced acid-dye blockers (colorless dye).
These acid-dye blockers have got a very high affinity for nylon and wool (meaning they’ve got a natural attraction to those fibers). Immediately upon application, the colorless dye begins filling empty or damaged dye sites on each fiber. This revitalizes lost stain resistance brought on by everyday wear or previous cleanings.
WHICH CLEANING METHODS CAN IT BE USED WITH? When given 10 to 15 minutes dwell time, the acid-dye blockers will have already filled the empty or damaged dye sites on each fiber. Using VacAway prespray/detergents having a pH of less than 10 will not remove the acid-dye blockers when you clean. Therefore you can utilize either Hot Water Extraction or one of the low moisture cleaning methods such as pad or bonnet cleaning. With any one of these methods you’ll get great cleaning, faster dry times and revitalization/enhancement of Stain Resistance in nylon carpet.
HOW ABOUT WOOL? On wool it is best to keep the pH of your cleaning solution to 8.5 or less... that usually means using either Encap GREEN or Peroxcellent as your prespray. The pH of Block-N-Boost is about 5.0, so when adding it to Encap GREEN or Peroxcellent the pH will be just fine. However, all dyes in wool aren’t created equal, so as a precaution, each wool carpet should be pretested for color fastness.
NOTE: Normally, wool is highly vulnerable to food and drink stains containing acid-dyes such as Red Dye #40 found in many foods and red children’s drinks. However, wool carpets cleaned properly with KleenShield Block-N-Boost, added to your prespray, will become highly resistant to these dyes and be given the protection they deserve.
WHAT ARE THE BENEFITS OF THE KLEENSHIELD BLOCK-N-BOOST ONE-STEP PROCESS?
1. It saves you money on chemicals (It costs less than ½ cents per square foot to enhance/restore the stain resistance on lightly soiled nylon carpet).
2. It saves you time and labor costs (Only using one-step, instead of two, means less time on the job and ZERO additional work for you or your employees).
3. It’s more affordable for more of your customers (More affordable means more sales and more money for you).
4. It’s convenient for your customers (There is ZERO additional dry time so your customers can use their carpets much faster than with traditional protection methods).
5. As a BONUS, your prespray will receive a BOOST in cleaning power.
HOW DO I SELL BLOCK-N-BOOST TO MY CUSTOMERS? Click one of the above images and watch the video on that page... It's easy!
To introduce Block-N-Boost, we are making the following special discount available:
$25.00 off any case of Block-N-Boost or $5.00 off any gallon.
We believe you'll find Block-N-Boost to be another great product to help you become more profitable for years to come.
