Old guys and their sticks
shadygrady
Rob Grady
I have looked at a couple of used cds vans, and it seems the old guys, when the speed control quits, just chop a broom handle or adapt a length of threaded rod to jam between the seat and gas pedal. There's always the excuse that "i didn't like the speed control". WTF?
Safety concerns aside, how would you like to have to adjust your seat every time you wanted to engage the cleaning unit, and fiddle with it to get proper engine rpms?
Wouldn't a proper replacement module or push/pull throttle give more peace of mind?
rick imby
Rick
They fixed it so they could finish a job or work for the day and realized it works. How many home projects do most of us have that are 90% done? But the roof isn't leaking so life goes on.
Reactions: Steve Lawrence
rick imby
Rick
Last summer I bought a new tub and surround for one of my bathrooms. It will be a tear out and replace... Still not done...
obviously stoopit ones
everybody knows an adjustable pole eliminates the need to move the seat
the hacks use these cheap ones
the pro's use the better ones
.L.T.A.
Reactions: Jimmy L
Roll a tape works good
Rob Grady
Rob Grady
There's got to be a better way. Gnomeisayn?
jcooper
Jerry Cooper
20180318_151938-jpg.78661
10 bucks says this fellow is from the south... Or he learned this trick from a southerner.
Brilliant, absolutely brilliant!
It's a magnet, right?
Rob Grady
Rob Grady
Southwestern Ontario actually, I put a tiny tach on a sparkplug wire and set the proper rims, Mark the spot that the magnet sits for precise startup.
This is on UncaErnie the Steam Genie. Works great
Crap is this what
I have to
Look forward too?
Is this why @Mark Saiger sells his every three years?
And why @AshleyMckendree got rid of his SS
BEFORE he became Marty or Jimmy?
Rob Grady
Rob Grady
UncaErnie was 78 years old when I bought this van from him via his nephew. It would take quite a few years of no maintenance to achieve the results of this unit.
He had the install done in Ohio somewhere, I'm sure a local yokel could have done better.
He had the install done in Ohio somewhere, I'm sure a local yokel could have done better. View attachment 78699 View attachment 78700 View attachment 78701 View attachment 78702 View attachment 78699 View attachment 78700 View attachment 78701 View attachment 78702
You'd be surprised how many people would use a puller to remove that pulley
Rob Grady
Rob Grady
Did you notice the custom made bracket for the clutch/alternator? Hand made by cutting out metal from the unit cage.
The drive shaft seems to work fine, but I will pull it out anyways for bearing replacement prior to reassembly.
Bawb's input is more than welcome, being the resident Genie guru.
Rob...see those two holes wit the threads in em......get two grade 8 bolts of same thread...and run them down till they stop. .then a quarter turn on each till it jus pops off....
NO PULLERS
How many years was it on the bottom of the sea?
