One earth question
Charlie Lyman
Charlie Lyman
the instructions give the dilution for RTU. What would be the dilution be for using this stuff in a last step injection system?
Reactions: Total_Rookie
J Brown
Jeff Brown
Is this a new product or is it just a name change for the DFC 210?
I have used that product before and didn,t have much success. Then I discovered procyon (similar product) and have been using it ever since. I use the procyon plus powder both as a prespray and a rinse. I use 16 Oz in a 1gal hydroforce (gotta mix it real good) 32 Oz in 5gal slurry metered at 2-4 gph or 3 Oz to 5 gal in portable
I've tried the liquids (carpet and Upholstery cleaner) and (extreme) and I just find the powder more cost effective even it's a pain to mix. The extreme liquid is too powerful for average cleaning. I have had it leach the color from black cords and even from my blue solution hose. It rinsed out but disconcerting when it happens.
So far I have not had an issue with Extreme. I wonder if others have.
Pretty simple, I presprayed with extreme and where my blue solution hose was lying, there was a blue streak. Where my black powercord was lying, there was a black streak. I'm not knocking the product, just saying be careful. I use it only on my worst jobs.
I don't doubt what you're saying. I'm just saying there has to be more to it. Cheap hose, boosters, or other product used in earlier situations. It's just not a problem for me.
Goodyear Neptune 3000 hose, no boosters or anything like that. Didn't happen just once. I have had other high Ph products do the same.
