ascrubabove
Is Paraflex still the shit now or what? Got to get some new hose! Is it best as a lead hose, to the house, or all the way?
Ruff Hewn said:been using Parker for 18 out of 21 years
i wouldn't hit a dog in azz with Ineptune .
It's an instant disaster waiting to happen
ACE said:How hot do you run atm larry?
This is almost the same set-up that we use . . .Art Kelley said:I'm loving my 3 100' Parker lines. They are all "inside hoses". Lightweight, and when they do fail, it's a little pinhole leak that hits you and it takes a few moments to realize what is happening. I use ther Goodyear hose hooked to the TM, a 50' one on the reel that goes to the house. An outside hose that will burst and spray boiling water everywhere. But it handles the high heat at the truck better than the Parker.
I also don't burn grass.
Marty said:I have personally experienced the hassle and annoyance of having the Paraflex hose wrap around my feet and knock things off tables and such. For me, the super coiling of the Paraflex was unbearable, for others it's the supposed problem with hose rumpturing. Everybody is different.
Personally, I have never had a Goodyear hose rupture on me, and I have been using it for almost 25 years now. What I actually DO see is the ends where they connect to the quick-connects getting soft. When I see that, it's time to replace the hose. That doesn't happen every 12 months like clockwork. It can be 18 months and in a couple cases I have got two years out of a hose.
Replacing my lead 50' section of hose is worth not having to put up with hose coiling up around my feet.
But then, while I am not a super rich cleaner, I am not a broke cleaner either and can afford to replace a section of hose when needed.
Ruff Hewn said:I also don't burn grass.
maybe high plains grass is different ...but it sure will burn Ohio grass
It won't melt/distort olie/poly cut pile though like steel braid
