I cleaned the carpet, odor persisted. removed pad and treated concrete. still smell urine. need solution quickly it is a condo unit waiting to be occupied. recleaned carpet after ward with power burst and citrate solve, worst smell ever. I recommended replacing carpet it is so bad. The owner will not replace. any advice, I must be done.by.Monday so no time to order chems!
I assume you have a water claw.
saturate carpet with water and extract two times.
if you don't have the oxi clean run to smart and final and buy two gallons of (or what you need)
of hydrogen peroxide.
pour on the carpet let dwell 20 min and extract.
repeat the process but do not extract all of the peroxide leaqve the carpet wetter than normal
cover the spot with plastic and go home
It would be way better if you can add baking soda to the peroxide.
this is how I mix it
16oz hydrogen peroxide
2 tablespoons baking soda
3 drops dish liquid detergent Yes drops. this just to create a chemical reaction.
If you do this formula. I would advise you to rinse the carpet with acid rinse. If you don't have acid rinse use
one cup of white vinegar to one gallon of luke warm water and spray it opn the carpet rinse with your tm.
Fluffy odor less carpet. the cl;ient wioll hug you and kiss you (hopefully it is not a man)
If you have any questions call me I have been using this formula for years and works beautifully. 310-872-0453
