extreme steam
I have just imported two air hogs (230 volt) and both of them do not start the vac on switch number 1. It seems very unusual that both have the same problem but they do.
The first machine....
I have checked that the cord works on the other plug so its not the power cord
It is the vac on the primary cord with the pumpout (which does have power).
Have checked all terminals and connections, they look fine.
Vac 1 works when the wires for vacs 2 are swaped over.
The switch works
Maybe its the component located above the switch?
On the second machine......
vac conected to the pumpout doesnt turn on, but the pumpout does.
vac on the same switch as the cooling fan circuit works just like the first machine.
Have not checked switches or vac with other vacs wires yet. was keen to get the first one working so we can use it.
Please help, I noticed the pumpouts must have been tested before shipping as there is water visible at the top of both pumpouts. So either the vacs were not tested or something has caused them to stop while being shipped. Very keen to get them going as they look like great machines! Have contacted mytee by emial and waiting reply but if someone can help me in the meantime then it would be great.
The switch works
