Poly and urine detection..
Is there something that actually works? I use a black light and a Hydrosensor and they are not working at all.. Any other tricks?
Cleaning Professional
Poly carpet is more difficult, due to limited absorption . . .
but a strong UV light should show fluorescence.
I have your light Larry, I love it! You would think I would be able to pick it up in the pad with the HS, right?
Always carry a box of Pomeranians. They'll find every single spot and pee on it again. If you can't keep up, your bare feet will tell you where they were.
Watch your language, though...
Take a spare. Pommies have a way of bolting out the front door and over the horizon.
Taking it for the team in the name of science and testing....
Reactions: Able 1
The nose is the best method when that situation occurs. But instead of looking like an idiot with your nose in the carpet, I like to put my nose in the top of my wand after I hwe over a spot I suspect is urine. The hot water will tell you quickly. Just keep your acid spray on hand, ready to resaturate the area.
Since you're in the hwe process, I don't recommend the enzyme process, because you have to wait 30min. Acid will work quicker to prepare it to rinse out.
