- Joined
- Jun 17, 2008
- Messages
- 1,693
- Name
- Billy Lewis
How many use poly tanks for fresh water? Any issues?
Jeremy said:The only thing I would caution you about is either installing a float shut off or being very careful when filling so you dont flood your van.
Bob Foster said:Works great and I have a shutoff float so it won't overfill.
Nowesco 150 gal vertical. I will be putting the same one in the next truck.
See through, easy to clean. easy to put bungs into with a large lid. And its light to keep the weight off the truck.
Mike Draper said:[quote="Bob Foster":36w2heo0]Works great and I have a shutoff float so it won't overfill.
I bought reloading gear. Had to special order a press and dies for the 50 and it wasn't $100 like you said
I did get 12 months no interest on most of it at Cabela'sMike Draper said:[quote="Bob Foster":2p4rr231]Works great and I have a shutoff float so it won't overfill.
Ron Werner said:I "had" a basic auto shut off, worked perfect.
UNTIL our local wise govt official said that there MAY BE a chance of siphoning the water back through the hose, the pipes, and back into the water system IF I was filling my tank and it overfills (ie theauto shutoff fails), IF there is a fire nearby and a firetruck somewhere near creates enough suction in the line off a hydrant to accomplish this, and IF it happens at the same time.
Now I have it rigged with a timer. I want 50 gallons, hook up the hose and set it for 15min
it shuts the water off and I'd have to bypass itBob Foster said:But what if the timer fails.....? :roll:
