Nov 15, 2011 #1 J joeynbgky Supportive Member Joined Jun 27, 2009 Messages 3,434 Name Joey What do you guys use? Say in a hydroforce? And a 5 gallon battery sprayer? says 8 oz to one gallon of water..... then says about using your flowemeter and metering... is it a detergent too? I'm confused how much to use
Nov 15, 2011 #2 T TimM Guest Joey, I use Powermaxx with my inline sprayer and on residential, I will use 2-3 scoops (4-6 oz) in the sprayer and I get very good results. On restaurants I will go 4-5 scoops (8-10 oz) in the sprayer.
Nov 15, 2011 #3 Lee Stockwell FOJL Joined Oct 7, 2006 Messages 18,851 Name Lee Stockwell 10 oz in a 7qt Spraymaster with 9:1 ratio.
Nov 15, 2011 #4 J joeynbgky Supportive Member Joined Jun 27, 2009 Messages 3,434 Name Joey Thanks so with a baytery or pump up sprayer I would use? Sent from my T-Mobile G2 using Tapatalk
Nov 15, 2011 #5 Lee Stockwell FOJL Joined Oct 7, 2006 Messages 18,851 Name Lee Stockwell Use enough to get the carpet clean. Then use a little less to confirm the "sweet spot". Bucket test your injections sprayers to confirm dilution and coverage.
Nov 15, 2011 #6 J joeynbgky Supportive Member Joined Jun 27, 2009 Messages 3,434 Name Joey Thanks u think il use 8 oz a gallon so 40 oz in my 5 gallon mytee big boss. Seems like alot wow. But it says 8 Sent from my T-Mobile G2 using Tapatalk
Nov 16, 2011 #7 Lee Stockwell FOJL Joined Oct 7, 2006 Messages 18,851 Name Lee Stockwell More like 3 or 4 ounces in your 5 gallon to get the same concentration I use. However induction sprayers like the HF or SM put the prespray on HOT and with more pressure.
Nov 18, 2011 #8 Larry Cobb Member Joined Oct 7, 2006 Messages 5,795 Name Larry Cobb Joey; With a TM . . . , you should only need 2-3 oz. per gallon for your electric sprayer. Higher concentration is for a portable extractor. Larry
