powermax dilution questions
joeynbgky
Joey
What do you guys use?
Say in a hydroforce?
And a 5 gallon battery sprayer?
says 8 oz to one gallon of water.....
then says about using your flowemeter and metering... is it a detergent too? I'm confused how much to use
TimM
Tim Magaw
Joey, I use Powermaxx with my inline sprayer and on residential, I will use 2-3 scoops (4-6 oz) in the sprayer and I get very good results. On restaurants I will go 4-5 scoops (8-10 oz) in the sprayer.
joeynbgky
Joey
Thanks so with a baytery or pump up sprayer I would use?
Sent from my T-Mobile G2 using Tapatalk
Use enough to get the carpet clean.
Then use a little less to confirm the "sweet spot". Bucket test your injections sprayers to confirm dilution and coverage.
joeynbgky
Joey
Thanks u think il use 8 oz a gallon so 40 oz in my 5 gallon mytee big boss. Seems like alot wow. But it says 8
More like 3 or 4 ounces in your 5 gallon to get the same concentration I use.
However induction sprayers like the HF or SM put the prespray on HOT and with more pressure.
Joey;
With a TM . . . ,
you should only need 2-3 oz. per gallon for your electric sprayer.
Higher concentration is for a portable extractor.
