Pressure Regulator Leaking
renegade_cowboy
I replaced my pressure regulator on my HMa couple of years ago and now its starting to leak down and out of the regulator shaft. Is there a rebuild kit, or should I just buy a new one?
Its the metal handle style.
KevinD
Kevin Dumas
If it is the one with the large brass knob they will usually take a couple rebuild kits
before they are completely whipped (worn out) brass body.
Bob will be along shortly claiming there is nothing better than a SS Paraplate
and WTF would use anything else.
I
idreadnought
If it is a brass one there is really only one o-ring in it. I rebuild mine in place on the truckmount. unscrew brass knob, remove c clip, turn machine on to an idle and gently pinch the return line going back to the tank. The plunger will fall into your hand. Change o-ring, I use viton ones, (get an assorted O-ring kit from harbor freight or ebay has a couple viton o-ring kits cheap). Then back together. 5 minute process.
have i mentioned how great these stainless Paraplate Reg are....
they's the cats ass
fo real!
oh yea.....WTF would anyone use brass?
KevinD
Kevin Dumas
Told ya
Told ya
Remarkable Kevin....now tell me which finger i'm holdin' up...... :lol:
renegade_cowboy
What size O ring do i need?
Johnny
Johnny
bob vawter said:
Told ya
I know its wrong to encourage BaWb, but :lol: :lol: :lol:
renegade_cowboy
Re: Pressure Regulator Leaking UPDATE
I bought the O rings, funny I had to buy 180 of them. How and where do I put the o ring at. I unscrewed it and it didnt have one in there so I have no reference. I tried a couple different places but it still leaks.
did i mention the Paraplate regulators.....?
renegade_cowboy
Bump
brent...i have no idea WTF you got there...but a picture would hep.........
can you put a penny behind the spring and get more pressure?
renegade_cowboy
Its the standard brass regulator that you find in HM machines. Least older ones.
KevinD
Kevin Dumas
I agree, post a pic of what you have.
My hydramaster took a special seal, not a o ring.
I'm sure they used different regulators through the years.
KevinD
Kevin Dumas
After you remove the brass knob can you pull out the stem?
If so does it have a rubber seal about the size of a dime and about 3/16" thick?
