Pressure Regulator Leaking
PA
I'm Rick James
I replaced my pressure regulator on my HMa couple of years ago and now its starting to leak down and out of the regulator shaft. Is there a rebuild kit, or should I just buy a new one?
Its the metal handle style.
KevinD
Binghamton,New York
Kevin Dumas
If it is the one with the large brass knob they will usually take a couple rebuild kits
before they are completely whipped (worn out) brass body.
Bob will be along shortly claiming there is nothing better than a SS Paraplate
and WTF would use anything else.
idreadnought
Oroville, ca
Richard
If it is a brass one there is really only one o-ring in it. I rebuild mine in place on the truckmount. unscrew brass knob, remove c clip, turn machine on to an idle and gently pinch the return line going back to the tank. The plunger will fall into your hand. Change o-ring, I use viton ones, (get an assorted O-ring kit from harbor freight or ebay has a couple viton o-ring kits cheap). Then back together. 5 minute process.
La La Land
have i mentioned how great these stainless Paraplate Reg are....
they's the cats ass
fo real!
oh yea.....WTF would anyone use brass?
PA
I'm Rick James
What size O ring do i need?
PA
I'm Rick James
Re: Pressure Regulator Leaking UPDATE
I bought the O rings, funny I had to buy 180 of them. How and where do I put the o ring at. I unscrewed it and it didnt have one in there so I have no reference. I tried a couple different places but it still leaks.
La La Land
did i mention the Paraplate regulators.....?
PA
I'm Rick James
Bump
La La Land
brent...i have no idea WTF you got there...but a picture would hep.........
can you put a penny behind the spring and get more pressure?
KevinD
Binghamton,New York
Kevin Dumas
After you remove the brass knob can you pull out the stem?
If so does it have a rubber seal about the size of a dime and about 3/16" thick?
