Pricing waterbox
PA
I'm Rick James
I am looking for a new/used water box, just wonder if anyone has any links for them.
everfresh1
Michigan
Jamie Cohen
Odin said:
something like this
price depends?
That box looks sweet Terje, I'm still planning on getting one eventually but I had mine repaired, and its ok for now plus I'm broke right now. Too many bills, one of my vans is down, and the wife is laid off. :(
brent said:
The waterbox I have now is about a gallon, kinda wanna shoot for that size.
buy Terry's poly one .
if you want stainless steel, have a fab shop make one to your specs.
You can save a few beans by drilling your own holes where needed.
If you go that route, specify stainless welds too, or you'll get rust water in the box
ask how I know.... :oops:
La La Land
this is the WB that i make..
it's a little under 200 bones but thats wit the bungs welded in!
check out the weld..purty
Ryan
Do you really need a water box?
From what I understand its used as a mix box on some TM's? If you have a fresh water tank why not just mix your chem's in there?
I bypassed mine... If it was detachable I would just send it too you but the thing is welded to the frame in about 5 places.
La La Land
they're callt TIG welds Larry..........
rwcarpet
Youngstown, Ohio
Robert Hodge
I put one of these on my Powermatic....holds 8 gallons.
http://www.northerntool.com/shop/tools/ ... ayer-tanks
Plastic....no rust.....last forever....have a screw on lid for water tightness.
dgardner
Phoenix, AZ
Dan Gardner
Brent, are you replacing a bad one, where the dimensions/port locations/mounting tabs have to match? Or do you have some latitude? A gallon is pretty small, most of the ones I see are 2-3 gal, about 6" X 12" X 9" high.
PA
I'm Rick James
Yeah the one I have is the original SS one. Sounds like you described mine to a T. I have alot of play of were to put it.
brent
AshleyMckendree
Versailles ky
Ashley Mckendree
Your tig welds are not as pretty as my gas welds :mrgreen:
