Pro 1200 SE suggestion
Why is Hydramaster never mentioned here?
Now that I have a Cleanco, they'll put their skills into future designs.
Now that they have a reason to survive.
Reactions: ronbeatty
I think the real reason is his sonny law refuses to ride with him.
I'd need ear plugs.
Scott S.
Scott
You can say Butlers are outdated, but the fact remains they are easier to maintain and run than any other unit on the market. Butler and Aerotech still support the first unit they built and they don't just stop supporting the units they made and say "screw you". The water ponds are installed in the vans half past the door post and low enough that you have to pull your vacuum hose over all your feed lines and water hose. Butlers are easy to run and fix. Fads come and go, we will see who runs the distance.
its not a pissing match ron. we already had multiple threads on this subject, i suggest that you read. all i did was point out that sapphire did not have a silencer, but had a differant blower that indeed causes less chop of the airflow reducing noise. thats all. get over yourself. And this is not a Mark vs Scott match. we both have valid points on each machine. in 5 years ill be still using sapphire. and will still be able to get parts, and still be running as im sure mark will be also.
Reactions: Sapphirerick
ronbeatty
Ron Beatty
Scott, I was not replying to anything pertaining to you, You are excited about your new equipment and I am glad that you like it. That being said, I have been buying equipment for forty years and know quality when I see it. Don't flatter yourself by thinking I care what you post because most of the time I brush over it.
Reactions: Todd Millar
Scott step back..............and ......tell us...............what brand of..............prespray you use.
Scott S.
Scott
just so your aware, i still have support for my rage and its 5 years old.. ... :rockon:
Scott S.
Scott
butler has some nice shelves, otherwise stuff would be sitting all over the floor.
ronbeatty
Ron Beatty
Scott, I was not implying that any particular slide in manufacturer was guilty of not supporting bad designs. Butler has always corrected any manufacturing problems, most of the time at their own expense after warranty was up. I don't run Butler's anymore but they are a top notch organization.
:lol:
Jimmy IF you were a normal person what would you want to be when you grow up?
:winky:
