Pro1200 in a Box
tmdry
Bill Martins
Mikey P said:
I have zero knowledge of the details, perhaps the person who sent the pics to me will comment.
What is the blower on those 1200s?
Model Pro-1200 Direct Drive
Vacuum pump Tuthill Tri-Lobe 5006. Vacuum to 16 in. Hg and flows up to 545 CFM.
Solution pump 1200 PSI CAT 5CP with high temp seals
Recovery tank 120 gal. (454 l) TIG-welded 3/16 in. marine-grade aluminum. 100 gal. (379 l) at shutoff.
Frame construction MIG-welded 1/8 in. × 2 in. powder-coated steel box tubing
Console dimensions 21½ × 31¾ × 36 in. | 55 × 81 × 91 cm
Power coupling 1 1/8 in. fully enclosed steel drive shaft
Retails $24k
Jim,
Looking at the pic the drive shaft is inside what you see similar to the butlers. It is a sealed bearing unit. Only difference I see is the Butler does not attach any wires to the shaft in the cab. I would be a bit concerned with those getting damaged
Dan
Dan
I noticed that too and thought it was kinda cheesy. Should have been safely routed under truck.
J
John Buxton
I've got a 1200 pro. heat and vac are great. My heat exchanger is needing replaced it rattles something horrible.
