tmdry
- Joined
- Apr 7, 2008
- Messages
- 2,508
- Name
- Bill Martins
Mikey P said:I have zero knowledge of the details, perhaps the person who sent the pics to me will comment.
What is the blower on those 1200s?
Model Pro-1200 Direct Drive
Vacuum pump Tuthill Tri-Lobe 5006. Vacuum to 16 in. Hg and flows up to 545 CFM.
Solution pump 1200 PSI CAT 5CP with high temp seals
Recovery tank 120 gal. (454 l) TIG-welded 3/16 in. marine-grade aluminum. 100 gal. (379 l) at shutoff.
Frame construction MIG-welded 1/8 in. × 2 in. powder-coated steel box tubing
Console dimensions 21½ × 31¾ × 36 in. | 55 × 81 × 91 cm
Power coupling 1 1/8 in. fully enclosed steel drive shaft
Retails $24k
