M
Marc Payne
Hello everyone I'm new here to the Forum.I'm located here in lovely wine country Past Roble's Ca.
So I have a prochem 405 and the problem is it will stay running when turn oil water bypass turn to the left but when I let it go it runs but real rough then eventually die. I change the fuel filter and sprayed carburetor with cleaner but I'm confused because
It's only when I let go of the dial does it run rough.
so if there was something wrong with the fuel system or carb wouldn't do it with the bypass turn to the left or not?
Could it be my fuel pump? is there a way of checking.
Thanks
Thanks
