I have 2 the first has 3500 hours sat along time and had the carburetor cleaned out ran fine for 2500 hours, It not runs great but sometimes in the middle of a job it will almost stall and rev back up like the governor if doing some thing with gas.
I end up pulling the choke completely out and it runs fine at that point.
Once I restart the machine it doesn't do it again for a couple jobs sometimes.
It seams to start when under heavy load?
The second question is my older 405 never draws more then 3 gpm from chemical jug and sometimes doesn't draw at all,I tighten things up replace any brass but the chemical system has always been a pita.
wondering if the govenor might be going on the first machine and just mad at 2nd machine its a fresh water rinse only machine right now
