Prochem Apex fuel delivery problem
It will hold up for a long, long time for you.. The Kubota is a solid motor.. The kubota is known to go 12,000 hours..
Never tried a kubota but I'd put that little nissan up again it . Over 18k. If I could of bought another one of those engines I would have.
Gene
XTREME1
Greg Crowley
the plug protectors are little rubber round thingys in around spark plug hole
DrUmM@sT3r
Mark Medora
I used to work for car dealership, we had a problem (Carbon Tracking) - so everytime we put wires on it, it would foul a plug & set a Check Engine Light. The GM tech bulletin stated the wires must be installed with "Di-electric grease" squirted into the wire cap then installing on the spark plug. What was happening is the plugs were actually shorting, and the porcelain cracked, & the spark was coming outside of the spark plug. Also a compression test is an easy check, if you have 2 cylinders over 100psi & the one is at 50psi - there's a problem. I run a Napa fuel pump & fuel filter on my '06 Apex-no problems. I change my oil every 100 hrs (synthetic 5w-30) and every 400 hrs, do plugs (NGK BKR4E gapped at 40mm) , fuel, air filters, chemical pump oil, & blower oil. Also I spray the carb with carb cleaner. We do have a problem with fuel boiling due to hot temps here - so you have to choke the hot motor to get a restart. Another thing I found is all the ground wires come loose at the left motor mount be sure it's good & tight. I'm running the original coils & wires from 2006.....
Mike Draper
Napa has a filter that is a bypass filter. It will keep cycling fresh fuel back to the tank so you shouldnt get that vapor lock from the heat. I've gotten that sometimes as well.
Keith
Yeah this one..
