Prochem Apex Uuhgain...
Jamesh921
James
My Apex will start and run as long as I hold the "Pump Override Switch" in the Override position. As soon as I turn it to the "Off" or "On" position, the machine dies. What causes this?
Thanks
Could be this
relay..
Could be oil pressure switch, or high temperature switch(less likely).. If you ground out your high temperature switch you can eliminate it.. I would start with the relay.
Reactions: dealtimeman
Jamesh921
James
Can you buy those locally? Or is that another non-proprietary part?
You should be able to feel the relay click when you put the key the the "run" position(not start).. There is a thread here about it.
Check your radiator fluid too if it gets low machine will die too. Probably what Able says it it's worth a look.
Not sure if the Apex has a low pressure switch either. With 405 you could bypass most switches with a wire to test them or trouble shoot.
Also make sure the float in the waste tank isn't stuck up or bad.
Reactions: Able 1
It's always good to run through the manual in the trouble shooting section to.
I actually learned a lot of this from guys on here.. Gardner and Martin helped me out a lot on this one..
Jamesh921
James
I found that the wire leading to the float valve had been pulled just far enough so that the connectors were pulled loose from the terminals inside the float switch housing. The wire wasn't pulled out of the housing, it was pulled just enough to disconnect it inside. Reconnected it and we're all good.
