rhino1
Old 100 A kerosene heater has a temp. control switch that the bulb end screws into the heater coil. It has two fittings that screw together with 2 brass inserts that look like washers with a slit in them. One of the fittings has stripped and needs to be replaced. The bulb end is connected to the thermostat with solder to(whatever you call the long copper wire) and there is no way to disassemble the thermostat to remove the fitting.
So, since the bulb end simply soldered on, does it just slide off if I heat up the solder, or does this whole control switch come as an assembly, fittings and all?
Sorry if this is hard to understand, can't really take the switch off for pics until I get a replacement.
