prochem water box overflow
wilpath
hey all, water box overflowing today, have a prochem everest, i see a rubber peice in bottom of water tank, does anyone know how to put in a new rubber tip or can it be adjsustedsomehow, ,thanks
It can't be adjusted just need to replace the seal on the ballcock valve ( about 10 dollars at your supply house) we like the black replacement and don't like the pink one so make sure to get the black one.
Unscrew the rod and ball from valve arm, take bolt out that hold the arm to the assembly, pull arm out and away from assembly.
Reach in and pull plunger from assembly, remove old worn/damaged seal and install new seal.
Install in reverse of above instructions.
Reactions: SamIam and Able 1
You're welcome from all of us.
Except Richard as he has told me several times of his dislike for most of the guys on here.
Even mentioning that some of them have terrible body odor.
