Bob Foster
- Joined
- Oct 8, 2006
- Messages
- 8,870
One of the issues I have with running high flow with a Judson TNT is even with its large waste tank when I'm doing larger jobs I run out of waste storage too soon. This is the very first reason that any of you contimpateing buying a Judson should go to the C4 if you run high flow. It has a larger waste tank.
The TNT has a larger waste tank than most units but running high flow I have run out of room many times.
Terje is going to build me a plastic waste tank that I can gravity dump into. That way I can get through those larger restaurants and other jobs without having to dump in the middle of a job. This should give me about another 40 gallons or so and then I will have a good match of 150 gallons of fresh water and a little more than the same of waste capacity. The lower tank will not be a vacuum tank but just a holding tank.
I'm going to mount it up between the frame rails with redi-rod and angle iron with an exterior grade plywood base
